LS/vtec obd0 to obd1
Old Aug 12, 2002 | 08:11 PM
CanadaCivic's Avatar
Default LS/vtec obd0 to obd1
Hey i have a b16a1 head on a b18a block. How do i convert this to OBD1??? Thanks for any help.
Old Aug 12, 2002 | 08:32 PM
kinesistech's Avatar
Default Re: LS/vtec obd0 to obd1 (CanadaCivic)
A simple question with no details is difficult to answer in such a way as to lend you any help.
Run it with an obd1 ecu. Pretty easy huh.
Old Aug 13, 2002 | 03:05 AM
Jeff C's Avatar
you will need:
1) obd1 ecu (idealy a chipped p28 w/o knock sensor)
2) obd0>obd1 wiring harness (contact blown90hatch)
3) to run several wires (to accomodate for 4 wire o2, vtec solenoid, vtec pressure switch)
4) obd1 distributor
5) to repin engine harness to match obd1 dist
6) heated o2 sensor
i believe that is it
xsi90teg
Jan 29, 2009 07:32 PM
efjones9
20
Dec 30, 2008 04:31 PM
slammedz6ef
Dec 31, 2007 04:13 AM
MniMeHatch89
May 24, 2007 09:10 PM
KevronsEG
12
Nov 18, 2002 07:57 PM
