Hearing a thin slightly ticking hissing sound when clutch is up
Old Mar 17, 2009 | 03:46 AM
MrSnake's Avatar
Default Hearing a thin slightly ticking hissing sound when clutch is up
Hi all,
I have a 1995 Honda Prelude 2.0i with 217.000 kms and for some time I'm having a non-stop sound/noise, like a thin slightly ticking hissing sound. It appears to originate somewhere on driver side or engine area.
The ticking/hissing is consistent and it becomes a bit faster when the rpm goes up.
When I push down and keep down the clutch pedal, the sound goes away till I let the clutch come up again.
Could it be the valves? Or something not keeping pressure?
First I thought it was my new audio installation (new speakers, amp, ...) and that the audio system was picking up some kind of distortion and amplifying it, but I also have the problem when the radio is turned off. (not sure if that can still cause unwanted results then)
I dont experience power/performance issues, but having that sound is just something that gets very annoying after some time
Anyone with some ideas or suggestions?
regards,
Peter
Old Mar 17, 2009 | 04:19 AM
Rude Awakening's Avatar
Daughter not possible
Default Re: Hearing a thin slightly ticking hissing sound when clutch is up
I've had that in about all my cars. Including the EG I have now.
Dunno. Its never messed up. Maybe the IS bearing. Does the car also "growl" noticeably in 1st gear?
Old Mar 17, 2009 | 07:10 AM
toomspeed's Avatar
if the noise is related to when you push the clutch in, then you could have a broke'n clutch spring, or weak hyd pressure for the clutch.
Old Mar 17, 2009 | 08:45 AM
Kronn 98SH's Avatar
check your throwout bearing.
Old Mar 17, 2009 | 08:49 AM
vtecb18c's Avatar
x2 on the throw out bearing
Stonage07
May 13, 2017 08:20 AM
Tuesdaynightfever
Nov 21, 2007 12:26 PM
RudyCholo
May 22, 2006 06:17 PM
2000gsrsedan
Aug 26, 2003 12:05 PM
