Is Radiator Different in Auto Than Stick
Old Mar 16, 2009 | 08:41 PM
sktyrhrtout's Avatar
Default Is Radiator Different in Auto Than Stick
Hey guys,
I have a 93 civic with a manual tranny. I have a radiator from an auto that I want to put in. I know it has the ports for the transmission fluid cooler, can I just plug those or do I need to get the manual tranny radiator?
Thanks,
Chad
Old Mar 16, 2009 | 09:12 PM
Blzdeep's Avatar
Default Re: Is Radiator Different in Auto Than Stick
Stay safe, get the right radiator.... im sure some may tell you to cap em, some may not. Easier to just eliminate the worries. IMO
Old Mar 16, 2009 | 09:18 PM
redbull-1's Avatar
In many cases, it the same part number, OEM and aftermarket. You can check your specific model here:
http://www.slhonda.com/parts/wholesaleparts.htm
Old Mar 16, 2009 | 09:20 PM
arrocha87's Avatar
i think u should be able to use it. i havent heard of ppl that do the auto to manual swap having to change their radiator.
Old Mar 16, 2009 | 09:21 PM
Hmm. So I can just throw a couple caps on that line then huh? That sounds good. Anybody ever done this?
Old Mar 16, 2009 | 09:25 PM
trout84's Avatar
Yes, you can put an auto rad in a manual car. The trans cooler just flows through the bottom, if you don't hook it up it does nothing and does no harm.
I have done this before, if it makes you feel any better
Old Mar 16, 2009 | 09:33 PM
Trout, you're the man. Thanks for the quick responses guys.
Old Mar 16, 2009 | 09:36 PM
trout84's Avatar
no problem, I'm all about not buying parts if you have used stuff you can rig up to work
Old Mar 16, 2009 | 09:37 PM
trout84's Avatar
oh, just be sure to drain it out real well before you install it, you don't want to leave a trail of transmission fluid on the driveway if you don't cap them off properly...
Old Mar 17, 2009 | 03:48 AM
94EG8's Avatar
Seagull Management
Yep.
Numerous times. My own civic has been like that for years.
Old Mar 17, 2009 | 04:45 AM
iliv2xlr8's Avatar
You can easily use the auto radiator for a manual car. However, if you are buying a new radiator, I recommend a 95 Del Sol Vtec one. They are a direct replacement but with a dual core design. They are excellent for better cooling for future mods.
-XLR8
Old Jul 16, 2009 | 12:11 PM
k20ex's Avatar
So does the tranny fluid run through the radiator, or does the coolant run through the auto tranny with the OEM radiator? Do I need to cap off these outlet pipes?
Old Jul 16, 2009 | 03:37 PM
94EG8's Avatar
Seagull Management
The transmission fluid runs through the rad, you don't even really need to cap the holes, nothing is going to leak. All the transmission cooler is, is a piece of brass pipe that runs through the lower rad tank.
Bush-15
May 26, 2009 09:43 AM
deeweezy187
Jan 5, 2007 03:26 PM
mike9571
Mar 12, 2006 09:05 PM
SamC
May 18, 2005 05:51 PM
sleepyhamsterlx
19
Aug 20, 2003 03:24 PM
