LS vtec mild all motor
I am building a Mild all motor LS vtec
B16 head
New Ferrea valve tran
buddy club spec 3 cams
S2 cam gears
S2 intake manifold
440 CC injectors
ARP head studs
B18A block
stock bore
type R pistons USDM
stock LS rods with ARP rod bolts
LS crank
Trans
Stock USDM B16
Using golden eagle LS vtec parts
I was wondering if this set up will not be far off the power of like a type R?
B16 head
S2 cam gears
S2 intake manifold
440 CC injectors
ARP head studs
B18A block
stock bore
type R pistons USDM
LS crank
Trans
Stock USDM B16
yeah i know they have a 84MM bore and i did not want to spend the money on a block and then go and by aftermarket pistons and rods...
are you serious? have you seen dyno graphs with this kind of setups? 180-190hp tops. to the OP, yes prob make as much power as an itr but not in the 200hp mark. with PnP and valve job you prob will break into 200hp.
From: where i stunt SAND CANYON in Southern California
here get a load of this ! using only ctr cams https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2Ab20vtec-build-dyno-graph%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A%2A-2486531/
here get a load of this ! using only ctr cams https://honda-tech.com/forums/showthread.php?t=2486531
