disk conv problem.
i have a problem getting my trailing arm aligned.i have a 91 civic si and i jus did a disk conversion outta a da.the forward-most pivot arm(i think dats wut its called) wont go in ne more.my trailing arm is flush wit the body so it cant come out ne more.i guess i need a longer forward-most pivot arm at least like an inch longer so my trailing arm can be strait.the bushings a torn already cause of that.ne ideas?
Did you reuse your factory toe correction link or did you swap it for the link off the DA? If you stated it before, I apologize, I just don't have the energy to completely translate what you wrote.
redman223
Suspension & Brakes
27
Jul 26, 2007 09:06 AM
