b16a bogging..jumpy idle when warm,hellp!
i have searched but cant find anything to help my problem. crx b16aobdo..it just bogs any seams like its goin to die at low rpms..if i get on it alittle i t will pick back up normal..
i cleaned the i a vc any other ideas thanks guys
Vacuum lines leaks ?
Dirty/Clogged Throttle body ?
Adjust the idle screw counter-clockwise a lil.
Check the tension on the alternator belt.
Check Fuel pressure.
Clogged/Dirty fuel filter ?
Take out the Hazard or ECU Fuse to reset.
Check throttle cable tension.
hatchdrvr
May 8, 2003 06:36 AM
