CEL 22 VTEC working, but falls out
Old Mar 16, 2009 | 11:02 AM
obuhmyuh's Avatar
Default CEL 22 VTEC working, but falls out
hey guys I've heard of this happening a few times where VTEC will be engaged but "fall out" (disengage) with a CEL 22 (VTEC oil pressure switch). I'm not sure if it's the actual pressure switch on the VTEC assembly or something else. The only thing I can think of that is oil-related would be a slightly leaking oil pan gasket (which has seem to get better with a slightly thicker oil). Any help would be greatly appreciated.
Thanks in advance
Old Mar 16, 2009 | 11:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: CEL 22 VTEC working, but falls out
first, where is the oil level?
Old Mar 16, 2009 | 11:19 AM
1988_96hb's Avatar
i was getting cel 22 on my gsr right after i did the swap and was told to run a ground wire from the vtec solinoid to the radiator support and it worked for me.
Old Mar 16, 2009 | 11:21 AM
Mr. Badwrench
ground your vtec solenoid to the rad support? care to elaborate?
Old Mar 16, 2009 | 11:58 AM
B16B_coupe's Avatar
HRD PKR
OP, check your oil level
check and make sure the pressure switch is pluged in and no wires are loose
Old Mar 16, 2009 | 11:59 AM
hard_boiled_EG's Avatar
don't know what it's call but under the solenoid the little block thing that connects to the head.. there's a screen..i remember taking mines off and there was alot of crap stuck in the screen that i guess can slow down or even stop oil flow to the solenoid...hope that helps...
Old Mar 16, 2009 | 02:24 PM
obuhmyuh's Avatar
oil is brand spankin new
screen is clean as clean can be, and the green plug busted off kinda like the part that makes it click in place so i soldered (hardwired pretty much) that plug to the harness. I did that a couple days ago and my work looked pretty good.
Old Mar 19, 2009 | 11:00 AM
obuhmyuh's Avatar
bump
justinwazner
Nov 12, 2015 05:14 AM
GraphiteMW
Dec 11, 2010 02:39 PM
NVMYDC
Aug 10, 2009 02:14 PM
mister2racer
Jun 26, 2005 07:13 PM
Exempt
Jun 3, 2005 02:34 PM
