b16a running rough in 92 vx
Old Mar 16, 2009 | 10:52 AM
Dravenm4's Avatar
Default b16a running rough in 92 vx
ok so i got this car it is a 92 civic vx hatch with a b16a from hmotorsonline.com... i got it and there was no knock or o2 hooked up in fact they were cut out so i replaced the engine harness wit h one out of a 94 del sol si. so then i repined the engine harness following a thread from here stating in needed to move these to convert 5 to 4 pin o2 and to add knock.... then i followed the same post moving pin d16 and jumping it to b1 for VREF at the ecu... and im am getting rough idle and slow throttle response. now before i got this car the car was dumping fuel bad now it is not (actually has o2 now thou). also I am replacing the TPS hoping for a fix to slow throttle response... but the rough idle and if you hit the gas hard it drops real fast and either dies or shudders a little and then goes back to idle... any idea's.
I really need help been replacing parts and have had very little sleep from working past 3 am every night????
Old Mar 16, 2009 | 12:08 PM
hard_boiled_EG's Avatar
Default Re: b16a running rough in 92 vx
if u can get your hands on a b series vtec engine harness..then follow this posting...https://honda-tech.com/forums/hybrid-engine-swaps-18/complete-obd1-b18c1-into-civic-vx-wiring-instructions-644434/ i have a 92 vx with a gsr swap and i used this posting and it worked out perfect...
Old Mar 16, 2009 | 12:46 PM
Dravenm4's Avatar
LMAO.... that is the article I was referring to... anyone have a gsr engine harness? Do you know what could be causing the rough idle and shuddering?
Notmyusername
Oct 16, 2017 08:30 AM
Hookeduphatch
Jun 9, 2008 04:20 PM
dr.garagetuner
Jan 5, 2008 03:30 PM
civicvx_2005
16
Jun 27, 2005 10:50 PM
sicx
Mar 22, 2004 11:34 AM
