Fs: Middle tenn. Silver 1997 civic coupe. 5spd. Clean. $3700
honda civic dx coupe. clean title.
location- murfreesboro tn. (middle of tenn.)
it is silver in color. (vsm)
155,xxx miles on engine and manual transmission.
190,xxx miles on chassis.
it's ready to drive daily. it runs great. no leaks, smoking, or knocking. you won't have to fix or replace anything. and of course you'll be able to test it out yourself if you are serious about buying.
the car is completely stock.
the a/c and the heat work fine.
the interior is clean.
the exterior is also clean with the exception of a little clear coat that is peeling off the rear bumper, hardly noticeable. there is no rust and i don't think there are even any dents.
the car looks great, and not junky at all like a lot of others.
PROBLEMS:
the windows and doors. the driver side window usually works, so you can still hit up the drive thru, but sometimes it randomly won't. the passenger side window isn't working. the power door locks also aren't working, you have to manually turn them to lock them. also, the driver side door speaker is not working, and the passenger side rear speaker sounds blown.
a little background information:
the chassis was originally a 1997 automatic civic dx and was stripped down to the seats only. the engine, transmission, ecu, and much of the interior came from a 1997 civic ex. so this civic is basically a civic EX without the sunroof. it has the d16y8 engine. you got to remember that when you do maintenance and get stuff like oil and air filters. also, the shifter sits further up because the hole in the chassis that the shifter comes through sits further up. (remember? the automatic chassis.) i didn't bother cutting out more of the hole, but you can do that if you want the shifter to sit normally. this doesn't affect the way the car runs and shifts. you just have to reach further when you shift to 1st, 3rd, and 5th. i just push it up into those gears with my fingers.
i will have pictures up by tomorrow. and if there are any questions you can PM me or whatever.
i want $3700 and i am not looking for trades or letting it go for any less.
you can also reach me by calling or text messaging to 615-839-4019
PROBLEMS:
Revolution2zz
Jun 5, 2007 02:33 PM
