Photoshop question
Old Aug 12, 2002 | 06:42 PM
BigZ88's Avatar
Default Photoshop question
How do you change the color of a car with photoshop? or can someone please photoshop this car to silver.
Old Aug 12, 2002 | 07:19 PM
BigZ88's Avatar
Default Re: Photoshop question (BigZ88)
if there is an easy way to do this that someone could tell me then that would be better than just doin it for me
Old Aug 12, 2002 | 07:22 PM
crxforum's Avatar
There you go.
CRX Forum
[Modified by crxforum, 4:32 AM 8/13/2002]
Old Aug 12, 2002 | 07:24 PM
bullz's Avatar
Default Re: Photoshop question (crxforum)
I'm a nooB to the photoshop program... this is a rookie atemp....
Old Aug 12, 2002 | 07:25 PM
BigZ88's Avatar
Default Re: Photoshop question (iLLestjr)
better than i can do
Old Aug 12, 2002 | 09:11 PM
ruiner17's Avatar
silver is hard to PS
Old Aug 13, 2002 | 06:45 AM
Vic Nyce's Avatar
Old Aug 13, 2002 | 07:30 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Photoshop question (Vic Nyce)
Mines more of a darker silver..
This is Hatchy-OwnzJo0, my bro's name wont log off for some reason..
Old Aug 13, 2002 | 07:59 AM
Vic Nyce's Avatar
Default Re: Photoshop question (Archidictus)
thats a nice color!!
Old Aug 13, 2002 | 08:28 AM
Unceasing Measure
that's me brudder
Old Aug 13, 2002 | 08:31 AM
Unceasing Measure
for that picture, go to image >>> adjust >>> hue/saturation
from there, go to the drop-down menu and select red as your phase and slide the bars around. if that doesn't work (as it very well may not), you need to select the parts of the car you want to color change and colorize/level change/color balance/hue/sat them until they look right. it takes a lot of practice but it's worth it
Old Aug 13, 2002 | 11:51 AM
BigZ88's Avatar
Thanks...i'll give it a whirl tonight
Old Aug 13, 2002 | 11:59 PM
ef civic's Avatar
here's some eye candy....
Old Aug 15, 2002 | 12:01 PM
Vic Nyce's Avatar
Default Re: Photoshop question (ef civic)
Old Aug 15, 2002 | 04:18 PM
bullz's Avatar
Wheels look better like that.
Old Aug 15, 2002 | 06:44 PM
ViZ's Avatar
ViZ
do you just cut the area you want to change color then paint over that layer in a solid then change the opacity so that the reflection shows through? or do you cut it out and change the hue and saturation of that layer or are there other ways of doing it
im know photoshop pretty well but i havent tried to edit objects color and such
[Modified by ViZ, 7:45 PM 8/15/2002]
Old Aug 15, 2002 | 06:49 PM
bullz's Avatar
Default Re: Photoshop question (ViZ)
The way I do it is I just choose the rim itself and then desaturate it (grey) so it gets rid of the color and then do a color change. Then adjust brightness and contrast and hue/sat so it mathces the light.
Old Aug 15, 2002 | 07:38 PM
Vic Nyce's Avatar
if its something with a strong color like blue or red, u can use the Image>Adjust>Replace Color tool. jack the fussiness to 200 and use the "Eyedropper+" tool to select the color range u wanna replace with the new color. then just slide the hue and saturation till u get the color u want.
for something with low color saturation, like white, or silver, or black, the method illestjr mentioned works best.
Old Aug 16, 2002 | 01:23 AM
Downey's Avatar
Old Aug 16, 2002 | 04:06 AM
bullz's Avatar
Default Re: Photoshop question (Downeybear11)
That a really nice finish Downeybear11.
[Modified by iLLestjr, 5:08 AM 8/16/2002]
2000EJ8
Paint and Body
Feb 21, 2010 07:48 PM
NACvicSi
Nov 30, 2007 10:56 AM
Scotty Dosent Know
Jan 18, 2006 09:48 AM
passinUby
Dec 4, 2002 10:55 PM
