Help speed sensor is stuck
I have a hell of a problem today i have to put oil in my tranny because i drained it all out but!!! my fill plug is stripped and the speed sensor broke and is stuck i tried to pry it off but it wont budge?! any suggestions?
yes. #6 in the picture is the reverse sensor. If i remember right, the nozzle at #14 will also work, but it will take forever because the tube is narrow.
You probably did, but some people totally don't know about it - did you take the bolt and little metal retainer off the tranny before you tried to pull the speed sensor out?
If you did take that off maybe try putting penetrating oil around the hole where the sensor goes into the tranny. I did this a few days ago and it worked. You have to let it sit so the oil can work it's way around the o-ring. I let it sit overnight and all it took was a little twist and it slid right out.
Kris05TSX
Transmission & Drivetrain
11
Jun 25, 2024 10:04 PM
