d2 coilover front fork problem
Old Mar 15, 2009 | 10:24 PM
trevorjohn88ef's Avatar
Default d2 coilover front fork problem
well i bought some d2 coilovers for my crx and i was puttting them on tonight and the lowe section doesnt fit tight with the fork on the fron of the car. heres what im talking about.
the gap
the size difference
and before you say tighten the bolt i have and it makes no differnce. and i know for a fact they fit a crx because i bought them of Private-tune on nwp (not sure if hes pon here)
trying to figure out why the gaps there. anyone with any input is more then welcome to post a solution. thanks.
Old Mar 15, 2009 | 10:46 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: d2 coilover front fork problem
save yourself some headache and measure the 2 peices. Measure the diameter of the bottom of the shock, and measure the internal diameter of the fork, full tight, without the shock in it. If there is more than about .25mm difference in diameter, then your coilovers are the wrong part for the car, or a really shitty design.
I could restate the obvious that yes, they do look a lot different, but measure them out to be sure, and then go back to whoever you got them from and demand the right part. Math doesn't lie, but some vendors might.
Old Mar 15, 2009 | 10:49 PM
i bought them off private-tune on NWP. he had them on his crx fro 2 years but there soooper minty. does anyone know if the 92-95 eg forks are a smaller inside diameter?
Old Mar 15, 2009 | 10:59 PM
sanimalp's Avatar
$cat /dev/urandom
judging by the pictures, i am going to go with a yes.
ANNiHiLATORS
Suspension & Brakes
Jun 21, 2012 07:20 PM
biggjerryc
Jun 17, 2008 07:14 PM
DeDonDeRosa
Mar 29, 2005 07:59 PM
Jaydo
Dec 9, 2003 07:50 PM
