emergency brake light
Old Mar 15, 2009 | 09:45 PM
g3Gsr443's Avatar
Default emergency brake light
The e-brake light comes on and off in my car, it comes on when im giving it more than 1/4 throttle in 1st and it will go away when i shift/let off the gas. i thought i could be low on brake fluid so i put some in. the light still comes on under the same conditions. what gives? my brake fluid cap seems loose even when tightened down, could that be the cause?
Old Mar 16, 2009 | 03:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: emergency brake light
maybe you need a new cap. There is a float under the cap that will trigger the light if it gets too low.
Old Mar 16, 2009 | 05:12 AM
jdmjoka's Avatar
DB squad #282
I got the brake master cylinder/ lid and all. 25 shipped. if you wanna try for that see if it will fix your problem
Old Mar 16, 2009 | 09:36 AM
g3Gsr443's Avatar
alright cool im going to check out the condition of that float. thanks.
and jdmjoka thanks but no thanks ik my breaks are still working. i can just go to the junk yard and find a new cap
Old Mar 16, 2009 | 10:59 AM
weavertime1's Avatar
You may also want to look at the wire that runs to the e-brake itself. That "sensor" lets you know the e-brake is on, and it could be out of adjustment or just bad. I doubt it, but I am just give you ideas. Good luck!
ef9gsx
17
Dec 15, 2007 01:49 PM
RedSuperRanger23
Dec 6, 2006 04:27 PM
nabisco33511
Jan 9, 2006 09:52 AM
ITAcelica
Acura TL, RL & ZDX
Apr 7, 2005 12:41 PM
ITRaholic
Oct 12, 2002 10:22 AM
