please help!!! DA integra front brake problem!!!
ok i recently bought some DA front knuckles and i was told they fit no matter wat they are a direct bolt on. well today learned the hard way that this is not true. i put them on and immediately as i drove off my car feels like my wheels are coming off. so i get out and everything looks fine. i removed the wheels to make sure everything was tight and it was. so i raised my car up a little higher and the vigorous vibrating continued however wasnt as severe. i heard that there is a spacer or something that has to be removed first??? anyone help me!!...this is my only car!!
get an alignment...
did the same thing.
they work just fine.
the difference is like 1/8in. but it makes your car feel like ***.
hope this helps
did the same thing.
hope this helps
do u think that worn tie rods would do this as well?...i really need to save as much money as possible so i dont wanna replace anything that can wait.
I had da front brakes with mc/prop valve/booster I had no vibration issues at all go get it alignment right away that is probably you vibratioins
i had a bent pass. side axle...unfortunately i didnt find this out until AFTER i took off the integra spindles and replaced it with mine...i would test them now but ive already put the whole set up for sale...thanks again guys
WiCked_Limitz
Feb 17, 2007 08:37 PM
