problems with my civic
Old Mar 15, 2009 | 06:06 PM
96b16sprayin's Avatar
New User
Default problems with my civic
i have a 96 civic with a b16 for some reason the idles fairly rough. i goes up and down and sometime when warming it up it completely shuts off. it also sometime sputters a bit while i'm driving. it usually takes a while before it'll finally start. i changed the plugs and i replaced the iac valve ( i thought that was the problem). I replaced the cap and rotor. Please help!!!!
Old Mar 15, 2009 | 06:59 PM
Turbowa's Avatar
Default Re: problems with my civic
Have you checked your coolant level and/or tried bleeding it recently?
Old Mar 16, 2009 | 07:59 AM
civicgsr's Avatar
It could be a few things. Is there a fast idle valve? If it has one, it could be bad. If not, then check for vacuum leaks and check to see if the throttle body gasket is leaking. (I got a donor motor that had a loose throttle body...similar problem you are describing).
Old Mar 16, 2009 | 10:29 AM
New User
i think the fast idle valve is blocked off with a plate but i'll check the throttle body thanks how can you check if it's leaking?
Old Mar 16, 2009 | 12:45 PM
civicgsr's Avatar
First check the bolts/nuts holding it on. Make sure they are tight. That gasket is really inexpensive. You could just replace it and see if it's better. If the t-body has been modified then it's been off. Could be a bad gasket.
jdmboy94
Oct 12, 2009 12:33 PM
Fastjato33
14
Mar 2, 2009 07:32 PM
go2sleep
Jun 27, 2006 01:36 PM
BOOSTEDgreeneg
Sep 18, 2005 02:46 PM
handa
19
May 24, 2005 03:43 AM
