Air/ Fuel Ratio Gauge
Hey guys,
i had a quick questions starting the turbo build on my sohc vtec. I bought a air/fuel gauge
1. Which oxygen sensor to i attach the sensor wire too?
2.What color is the wire is the sensor signal wire?
(i have an OBDII d16y5 with a z6 vtec head)
Thanks guys,
Thanks guys,
if you are asking what sensor it hooks to, you have a narrow band gauge. to put it bluntly, it is useless because the ratio a turbo engine works in doesnt even register on that gauge.
you need a true wideband af gauge.
but to answer your question, at the sensor, it is the should be white with a shield on it.
okay i got white but what O2 sensor is it the up stream or down stream?
djjosehernandez
Sep 19, 2008 04:18 PM
maddcrx
Honda S2000
Jun 26, 2008 03:55 PM
