How hard is it press out wrist pins on oem honda pistons?
I was thinking of cutting a piece of 2x4 like half of it 81mm so the piston will sit in it and i can use the 11mm socket to press down on the wrist pin to push it out. Im just trying to save some coin places around here want $60-80 to take off and intall pistons. I got access to a press.
Take your time and get a good fit between the piston and the base your pressing against.If your tossing the pistons it's not as important,but if your going to reuse them it is critical.I heat the rod to assemble them.You only need a light straw color,you don't want it glowing red.
Ok im just trying to do a budget ls setup . I got a set of GSR pistons im gonna slapp on the LS rods after i send them to get arp's put in them.
TravisBiggie
May 27, 2012 05:45 AM
