Timing Belt Swapped, Now It Won't Start, HELP!
Old Mar 14, 2009 | 11:25 AM
spender1326's Avatar
Default Timing Belt Swapped, Now It Won't Start, HELP!
Here's the story.
My timing belt wore out. It didn't snap but the teeth wore down and engine just died. I didn't realize this until later. I may have cranked it too much and crashed a piston into a valve.
I got a new timing belt and swapped it out today. I did everything right. I've done it before.
Now it won't start.
It would crank and would try to start but will not start. I felt the headers and it appears that only one cylinder is getting ignition. The header pipe off of #3 cylinder is warm after cranking, which means ignition. The other three header primaries are all cold.
Questions: Is it possible that I bent the valves so badly that the engine won't start? I thought bent valves only causes bad running ... not "can't start"
What else should I test?
Help! Anyone. Thanks.
Old Mar 14, 2009 | 12:04 PM
Jdmtuned's Avatar
From: Long Beach/Riverside, California, United States
Default Re: Timing Belt Swapped, Now It Won't Start, HELP!
compression and leak down test?
Old Mar 14, 2009 | 05:51 PM
j_bizach's Avatar
+2 on the leak down test. Double and triple check ur timing marks and make sure the belts tight. If you come up with bad compression across the board ur timing is proly off. Bad compression on just one or two cyliders ur proly bent a valve.
jeffriesjr
Apr 1, 2019 11:01 AM
ddn1313
Aug 4, 2018 02:46 PM
sd619jef9
18
Aug 25, 2012 10:35 AM
roorensu
Oct 17, 2007 10:38 PM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
