Shifter bushing question
Old Mar 13, 2009 | 06:46 PM
Type-R32's Avatar
Default Shifter bushing question
Does anyone know how to install the shifter linkage bushing that connects to the tranny easier and faster, it so hard to push in, any tips or tools that could help me do it? tried a c clamp still to hard. thanks
Old Mar 13, 2009 | 06:51 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Shifter bushing question
Have you tried lube?
WD-40 or soapy water should help you..
Old Mar 13, 2009 | 06:53 PM
jhammond_82's Avatar
Reject Papi
yeah, some of those bushings are a bitch to get in. i put the bushings in my swap linkage, and it was hard, i used wd-40 too.
Old Mar 15, 2009 | 07:34 AM
Type-R32's Avatar
aii thanks, was yur bushings poly urethane though
Old Mar 15, 2009 | 08:46 AM
Reject Papi
mine were, yes.
Old Mar 15, 2009 | 11:09 AM
zrickety's Avatar
I wouldn't recommend wd40 for plastic/rubber parts...it can eat them up. silicone spray or soapy water will be better
Old Mar 15, 2009 | 11:17 AM
Dark_Teg's Avatar
Dont try to push it straight in, put the bushing in at an angle. get one side to start in and then just pop it in.
Easy money.
Old Mar 15, 2009 | 02:26 PM
Reject Papi
i've only ever had that problem on cheap roller blade wheels when i was like 12. i think a higher quality material would be ok. i mean, its going UNDER your car. rocks, dirt, road salt, cats, and **** will be hitting and getting all over those bushings. an oil leak. ect....
hillbillycivic
Mar 13, 2013 08:14 PM
GuCBlackEk
Apr 7, 2010 03:28 PM
elmalouno
May 2, 2008 08:37 AM
slash00R
Jul 9, 2003 01:15 PM
ahead
Jan 30, 2003 06:41 PM
