what cam to buy
i want to buy skunk2 cams but not sure what to go with . how much power will i gain with the skunk2 cams and will i pass the sniffer i live in ca. also it is a 97 jdm type r
imo i think blox are much better because they are cheaper and pretty much have the same specs as skunk 2
get jdm stlye type-r cat(2.5) the stage 2 tuner series cam is great for what you need. compression is not too high, good fuel economy, very streetable, but big notice in power gain. Any cam with same specs as the S2 stage 2 tuner series will be fitting. just remember you should use a header w/ 2.5" donut and 2.5" axle back
the stage one is a great fit but also should be tuned since this entire motor is no longer a GSR
i should pass, but like they said w/ no cat forget about it!!! DOnt get stage 2 unless you plan on doing smog then putting them in, and taking them back out when you need to re smog again.
alpha_1
Apr 10, 2008 04:49 PM
sirshan
Jan 24, 2006 01:08 PM
