Civic VX Motor into a CRX Si
Ok well ive seen quite a few threads about getting 50+ mpg (when u take it slow) and having 130 hp with vtec. And I am getting ready for this now just becuase when gas hikes back up to 4-5k bucks a gallon i wanna be ready on the information side of this. i have quite a few questions so please be patient with me.
As for bar'ing i was thinking that i would need, motor/tranny, wire harness (or is a adapter good enough?), and the correct ecu correct?
1. this is true correct? 50+ mpg 130 hp vtec?
2. Exact D15 model of the vx?
3. what all do i need for bar'ing this into my 90 crx si?
I do use the search function and do reply in other threads but i want my own thread, please dont leave nasty comments.
Apon looking around i see that i was given quite abit of mis-information. maybe i heard that a jdm d15b something was the 130 hp 50+ mpg.
VX Hatchback Key Features:
1.5 Liter, 92-hp, 16-Valve VTEC-E Engine, Lightweight 13" Alloy Wheels, P165/70 R13 All-Season Tires, Chin Spoiler, Tachometer, Dual Manual Remote-Operated Mirrors
http://www.gassavers.org/showthread.php?t=834
edit: just adding more hyperlinks for my info collecting thread.
http://forums.vwvortex.com/zerothread?id=3813631
No no no you're thinking of the few 3-Stage VTEC D15B threads that have been floating around lately. The VX (D15Z1 or JDM D15B VTEC-E) will get 65+ mpg when cruising but will only make 92hp peak. The problem with getting a 3-Stage VTEC setup together is you can only use the stock ECU and it's virtually impossible to find a manual trans 3-Stage VTEC ECU (I'm looking).
Wow finally an interesting tech question, it’s been a long time. The short answer is yes, anything is possible with the right amount of money. To make 135 and get 50+ mpg, you could do a small turbo on a vtec-e engine. The vtec-e came in the vx hatch and the hf models. It uses a low lift on the primary cam lobes to create a swirl effect that promotes better or more complete combustion. It also uses a lean burn system while cruising, where the ecu will run as lean as 19 to 1 air fuel ratios or so I’ve heard, but at the very lest it is much leaner then stoch 14.7 to one. Reason I care is I just picked up a 95 shitbox vx that I’m just using to cruise to work and around town. The engine in it, is in pretty bad shape so I ordered a new (used jdm) b15b for a few hundred bucks to replace it. The plan is similar to yours, get good gas mileage. I don’t really care about power as my ef has that covered. The easy way to do it would be, source a jdm b15b vtec-e, convert your car to obd1 and get a chipped ecu and just tune it to run lean in the driving parts of the maps. Then if you’re looking to up the power, turbo it and add power within the constraints of the d series engine. No reason you would not be able to have 140hp and get 50 mpg. It’s just how cost effective will it be, I don’t know you have to answer that yourself.
Thank you all.
Ok then I guess ill get started and at least start looking for a motor.
To the last person, I'm not really looking for a powerhouse. I just love the crx. So 92hp is what I had in my dx (last crx) and that was fine with me. I'm thinking of doing the swap only for mpg. I love the little crx and I'd love to have it get 50+ like a very nice hf but still have all the si things (black interior, ac, my stock dual tip which are so hard to find lol). I've just heard from many people we'll be looking at 4 to 5 bucks a gallon gas by the summer. So I'm just preping the swap for when the time comes. I would double my mpg for 20 less hp anyday.
I made a thread about doing this project and it's been postponed for now.
It took me 8 months to track down the P2J ECU(Manual version)and that's going through a well connected jdm parts supplier.
I have the motor, the ecu...now I need to have a custom wire harness made to make it plug n play. I am not sure if the ecu is OBD2a or b. Anyway, the point is I still have to send both my OBD0 and OBD2(from the D15B)to Rywire. The engine has an EGR valve and a few other sensors that I am unfamiliar with.
You could wire the motor to run like any other SOHC vtec setup, but like you I want the engine running the way it was intended.
Thank you all.
Allthough my one of my CRXs has much more power I'm acctually doing a VX swap into the other and the 90hp it has now is still "fun" and so is the 92 Civic VX a friend of mine has.
i don't see why you couldn't just use the free version of crome (if they still have it) convert the d15b to obd1 and just tune it your self. i might be wrong though, i've never really looked into it because i have a vx already. good luck and let us know if you have questions we can help with.
D15B 3-Stage VTEC: There are 2 VTEC solenoids and a 5 wire O2 that you cant just magically plug into any other ECU.
D15Z1: Still has the 5 wire O2, you can't tune a regular ecu to decide to go into lean burn mode when you're cruising.
You could make it run but you'd defeat the purpose since you could never tune it to safely run as lean as stock.
HX D16Y5 = EX D16Y8 with a VTEC-E cam... D15Z1 = a REAL fuel milage built engine
I'm not sure who you're replying to and since there are two engines being discussed here...
V/R
Thank you all.
The D15Z1 single stage VTEC-E ECU is readily available since it is USDM. I've been looking into this since I swapped the 70HP HF motor and trans into my CRX DX. 92HP is looking good to me. Here I am on a D15Z1 thread less than 3yrs old. Hello.
You'll need OBD-1 of course and the VX ECU.
Vtec wiring
EGR wiring
SIL wiring (optional)
5 wire "o2" wiring
possibly other wiring (my HF swap required additional feedback to the ECU regarding clutch and A/C)
fuel feed line
EGR control box
oil cooler lines
tall transmission
lighter weight... your VTEC-E engine might come with the lighter brackets. HF and VX/CX had lighter (list unavailable at this time).
I have access to wiring diagrams, but there's a pinout of the OBD-0 to VX ECU on the wub. I'll post a link
http://www.crxmpg.com/
some of it was 404'd last time I visited.
It's the manual trans 3-stage vtec ecu thats hard to find.
Also idk about the HF or CX but the VX has aluminum a/c and alternator brackets
I have a VX engine in my striped 88 Hf, and it gets 70+ mpg. I don't hypermill or anything really any more, so I've had a few lower 70 tanks, but 70 mpg is better than what prius owners are netting.
WTTTFFFF
I only get 30 mpg in the city, driving like a freaking granny, with a d15b2. 92 hp. How the hell are you guys getting such good gas mileage? I calculate mine accurately, none of that 450 miles a tank = 45 mpg bullcrap
JesseCRX
Aug 2, 2008 12:52 PM
slayersluck
10
Sep 15, 2005 04:58 PM
