Car Feels weaker sometimes.
Old Mar 13, 2009 | 06:04 AM
PphamEK's Avatar
Default Car Feels weaker sometimes.
Whats goin on ppl. Well i have a 95 hb with a b18c swap. Sometime my car pulls weak when its warmed up and pulls hard when it not fully warmed up. Whats up with that. Ive changed my dizzy rotor and it felt better, then like 2 weeks later its started acting up again. U guys think its a fuel problem or ign? what should I do? and my temp gauge was kinda of workin then drop to cold. chaged the thermostat and now its the temp gauge isnt even working period. the sensor is pluged.(bad sensor?)*** me right?
Old Mar 13, 2009 | 06:32 AM
B.'s Avatar
B.
400 HP Club
Default Re: Car Feels weaker sometimes.
what ecu is in the car?
Old Mar 13, 2009 | 06:38 AM
PphamEK's Avatar
stock p72
Old Mar 13, 2009 | 06:43 AM
B.'s Avatar
B.
400 HP Club
how long ago did you do the swap?
Old Mar 13, 2009 | 06:47 AM
PphamEK's Avatar
Like around 2 yrs now. like ur Eg man ***** sexy
Old Mar 13, 2009 | 06:51 AM
B.'s Avatar
B.
400 HP Club
thanks man. 2 yrs, hmm there goes my suggestions lol. IMO take it somewhere and have it looked at. It's hard for me to really understand the issues unless I can see/hear the car. Sorry man. Good luck.
Old Mar 13, 2009 | 07:10 AM
PphamEK's Avatar
yea, i was thinkin of that. well thanks anyways, its worth a try
Old Mar 13, 2009 | 07:13 AM
godspeedcrv's Avatar
you may need to have your ecu tuned to understand the fuel and air it should be getting. Since you didn't mention any misfiring, that may exclude any ignition issues. You may just be running lean or rich depending on the outside air temp. (my opinion)
Old Mar 13, 2009 | 07:19 AM
Nautical_Star's Avatar
Have a compression test done and see if any cylinders are misfiring.
Old Mar 13, 2009 | 07:34 AM
PphamEK's Avatar
really? but the ecu is for that motor... so shouldnt it already understand the air and fuel mixture?
Old Mar 13, 2009 | 07:35 AM
PphamEK's Avatar
yea ima try that out. whats gud compression like 180?
Old Mar 17, 2009 | 08:42 AM
mouab18c1's Avatar
you have a b18c with a usdm p72?
Old Mar 17, 2009 | 09:16 AM
95vxtealhatch's Avatar
my d15b had a problem similar to this one. It was my IAT sensor getting heatsoaked, and thats caused the ecu to retard my timing over 5 deg. ECU retards timing when it see air temp over 130
Old Mar 18, 2009 | 11:52 AM
PphamEK's Avatar
i belive its ajdm p72
Old Mar 18, 2009 | 11:53 AM
PphamEK's Avatar
IC where is the IAT located at in a b series? and how can u tell if it messed up?
B00stedEh3
Oct 9, 2011 01:41 PM
JDMpride
19
Nov 30, 2010 11:31 AM
Powelly
Jul 30, 2006 09:02 AM
onyx00
Dec 2, 2005 08:22 AM
NeoGSR
Jan 17, 2005 11:27 AM
