b16 redline at 7200?warm up issue
My obdo b16 won't go past 7200 rpm.could this be because it's not warmed up?some other guy whooped me in his b16 Rex bc he could hold WOT.mine kept sputtering.is there any way to bypass this or make my engine warm up faster?it's a stock ecu
Racing other cars doesn't classify as babying a car last I checked.
But what do I know, I've never babied any of my cars.... They aren't made for that.
i was driving my car for a good 15min and it still wont hit 8200.it basically cuts out at 115 or 7200.i was driving for a while though.
Does it ever reach operating temp? Sounds like you have a stuck open thermostat or the thermostat that is in the car is to low of a temp and the fan kicks on before the car gets up to normal operating temps. Is your fan hooked up like stock where it kicks on at a certain point and to a plug or is it wired to run as soon as the key is turned on?
Also what ECU are you running?
115 is the stock speed limit. Does the thermostat open up? One time I recieved a JDM block with a low temp thermostat and in the middle of winter the thermostat would not open up.
