Replace Fuel Pump
DIY:
1. Jack car up from the rear tow hook, place jackstands under rear jacking points (block front tires and leave trans in gear.)
2. loosen the straps that hold the gas tank on but don't completely remove them.
3. Once the tank is lowered a bit, go about removing the hoses and wiring from it so it's not attached to the car by anthing
4. Lower tank the rest of the way using a peice of wood and the jack you lifted the car with (try to do this with a near empty tank, its a lot easier)
5. Change pump.
6. Put everything back together.
Dont forget the
5. Change pump.
Dont forget the
enjoi_hendrix
Sep 7, 2009 07:41 AM
puertoricanboy90
Dec 26, 2008 03:41 PM
