Lighting HID/Xenon kits, Retrofits and Associated Topics
Help my fog lights don't work
Old Mar 12, 2009 | 05:54 PM
b18c1vtecdc2's Avatar
Default Help my fog lights don't work
These are the steps i followed except I used the orginal switch instead of the CC button http://www.team-integra.net/forum/di...1&ThreadPage=1
These are the 94-97 si-vtec "ebay" replicas
i started off first hooking the fogs then to this brown piece then i ground the other wire
then i wired the yellow wire to this other brown wire by the Cruisce Control ecu/by dead pedal
next i wire the black wire to the fuse box
last i wire ground the last wire
I am not sure why it is not working i wire the lights to the battery to check if it is the lights but its not, they work. I heard the relay is suppose to make a noise also? but it doesn't make a noise help me please
Old Mar 13, 2009 | 07:50 PM
striker_18's Avatar
Default Re: Help my fog lights don't work
brown plug doesnt look to be all the way in.
Old Mar 15, 2009 | 08:47 AM
PMK's Avatar
PMK
That brown plug sometimes doesn't sit and plug in correctly. I cut mines off slapped on a connector and plugged it in hard, works good.
Old Mar 17, 2009 | 07:24 AM
Phat_97_LS's Avatar
Yup did the same thing cut off all of the plugs and attached oem ones from the junkyard on. Works perfectly for me, no more crappy plastic breaking everytime i take unplug them.
Old Mar 24, 2009 | 09:21 PM
kckchjchfc's Avatar
either the plug or not a complete circuit or not enough voltage. cuz if it was the bridge in the relay would come down making the pathway..so ya one ouf those. or its broken. go to a shop.haha sorry man. just put some bubble gum and duct tape. itll work fine.
JDMarshal
Lighting
Aug 3, 2010 03:44 PM
b18c1vtecdc2
May 29, 2009 10:29 AM
energ3tic2
Jul 10, 2008 04:50 PM
ScuderiaFerrari
24
Nov 8, 2004 07:41 PM
