Help my fog lights don't work
Old Mar 12, 2009 | 05:49 PM
b18c1vtecdc2's Avatar
Default Help my fog lights don't work
These are the steps i followed except I used the orginal switch instead of the CC button http://www.team-integra.net/forum/di...1&ThreadPage=1
These are the 94-97 si-vtec "ebay" replicas
i started off first hooking the fogs then to this brown piece then i ground the other wire
then i wired the yellow wire to this other brown wire by the Cruisce Control ecu/by dead pedal
next i wire the black wire to the fuse box
last i wire ground the last wire
I am not sure why it is not working i wire the lights to the battery to check if it is the lights but its not, they work. I heard the relay is suppose to make a noise also? but it doesn't make a noise help me please
Old May 29, 2009 | 07:29 AM
Hatorade's Avatar
Default Re: Help my fog lights don't work
Did you solve this yet? I am having the same problem. (except my switch works/clicks, just no light)
btw...the fuse box plug goes into the 2nd or 3rd plug hole from the right
Old May 29, 2009 | 09:57 AM
phoshyzzle's Avatar
i had the same problem. i hooked up all the wires direct since the plugs wouldnt work. they didnt click, or make contact. i just took the wire out of the plug and it still plugs into the fuse box. just use electrical tape to hold it in. after two weeks my fog light bulbs blew so i suggest getting new ones before you put those in.
Old May 29, 2009 | 10:29 AM
Hatorade's Avatar
^^ nice!! I'll start by removing all those cheap ebay plugs!
did you also replace the "Fog light Housing" to "Engine Bay Harness" connection?
it was the white male to white female plug.
thx!!!
JDMarshal
Lighting
Aug 3, 2010 03:44 PM
b18c1vtecdc2
Lighting
Mar 24, 2009 09:21 PM
energ3tic2
Jul 10, 2008 04:50 PM
ScuderiaFerrari
24
Nov 8, 2004 07:41 PM
