Aftermarket intake manifold ? on OBD2B 2001 GSR
Old Mar 12, 2009 | 10:50 AM
variable's Avatar
Default Aftermarket intake manifold ? on OBD2B 2001 GSR
How can I change the ECU tuning in my 2001 GSR for the Blox intake manifold? I was going to run a chipped P28 with and OBD2-OBD1 jumper harness, but I have been told my car wont start because it has an immobilizer in the ECU...please help I need some advise on this I'm stuck
Old Mar 12, 2009 | 11:32 AM
418whpturboD's Avatar
Default Re: Aftermarket intake manifold ? on OBD2B 2001 GSR
yes you can do this and it will work just fine.. i never really liked the stock gsr intake manifolds..
Old Mar 12, 2009 | 11:44 AM
iH8RICERZ's Avatar
You'll be fine if you run a chipped p28 w/ an obd2B-1 harness.... the immobilizer is only in the stock ecu. Once you cover to obd1 and run the ecu, it eliminates the immobilizer function. Just make sure once you get the single stage intake manifold and the chipped ecu, you go and get your car tuned.
Old Mar 12, 2009 | 02:33 PM
variable's Avatar
Thanks guys
goofygamer
Engine Management and Tuning
27
Apr 23, 2011 10:24 PM
ekgsr99
Aug 31, 2009 06:57 AM
variable
Mar 12, 2009 12:08 PM
tree fingers
Apr 20, 2008 07:40 AM
92 CiViC gsR
Mar 8, 2002 02:18 PM
