new to neptune, need a good coach
Old Mar 12, 2009 | 06:55 AM
19slocivic97's Avatar
Default new to neptune, need a good coach
i'm not trying to tune my car, i just want to heat cycle a couple of times before i get it tuned, my problem is that the car is dumping gas like a mf, i followed the directions for basmaps on hrtuning.com, the ecu is a p75. i loaded p28 and then p72 map. also i entered my injector size at 1000 but it doesnt seem to change the fuel map, that may be my problem i hope, my a/f are in the 9s.....please help....james i know you're out there waiting to give some great cust. support....thanks in advance
97 civic
gsr, 9.0 cr, rods
rc autoworks ram
t3/t04e
1000cc prec
Old Mar 12, 2009 | 07:57 AM
HRTuning's Avatar
Default Re: new to neptune, need a good coach
It doesn't change the way the map looks, but it doesn't change how much fuel goes in. You can see that in the datalogging where it shows fuel value. You can subtract a little extra fuel by putting a negative number in the overall trim on top of what it's already taking out for the 1000cc injector size, or adjust the map itself.
Old Mar 12, 2009 | 09:34 AM
thanks james, i can get it to start but it doesnt want to take any throttle input and it wont idle on its own, also i get different codes, if i look at the list i'll have a 1, and 3, then if i hit update i get 1,3,5,6,8, then if update again i get 4,6, it just seems if i push update i get a different list each time...i'm lost
Old Mar 12, 2009 | 10:27 AM
got it strait, i loaded a tuned map that was close to my set up and it fired up and idled great, map was just a little rich but got that strait, as always thanks for the great support james
Old Mar 12, 2009 | 12:55 PM
HRTuning's Avatar
No problem. Glad you got it working.
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
raverx3m
Sep 30, 2013 07:04 PM
ashb82
11
Aug 3, 2012 01:22 PM
Civicman86
Mar 24, 2007 01:15 PM
xci_ed6
May 20, 2002 05:45 AM
