Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 accord ex
Old Mar 12, 2009 | 05:20 AM
soon2bdropped's Avatar
Default 04 accord ex
sup guys i got a 2004 accord ex with 54k miles on it.. ebrake does not hold at all. what could be the possible problem or the most common problem it does have the rear disc brakes.
how do you remove the glovebox to replace cabin filter.
is there any DIY on changing the drive belt thanks
Old Mar 12, 2009 | 11:08 AM
asnstyle22's Avatar
Default Re: 04 accord ex
6spd? theres a timing chain on the thing..as for the accessory belt.. not 100% sure but dont you just push the tensioner and remove the belt?
glove box, theres a stopper that holds the glovebox up and keeps it from openning all the way, that stopper can be removed and the glovebox will drop right out =P
also... ebrake thing.. have you tried to adjust the cable? im not sure what the proper way to do it is but i removed the center shifter area to access the ebrake and there is like a "Y" thing that you can tighten. i believe you can also adjust it directly at the rear calipers but i have not done that myself.
Old Mar 12, 2009 | 05:39 PM
redbull-1's Avatar
Drive belt:
http://www.driveaccord.net/forums/sh...t=22786&page=2
Cabin filter:
http://www.micronair.us/assets/pdfs/246.pdf
Old Mar 12, 2009 | 07:06 PM
anyone else know about the e brakes? its a disc in the rear..and maybe it needs adjustment or something... anyone know.. thanks redbull
Old Mar 12, 2009 | 07:15 PM
redbull-1's Avatar
Parking brake check and adjustment:
Old Mar 16, 2009 | 04:33 PM
im doing the belt tommorrow so your telling me one bolt holds all 3 belts? let me know thanks
Old Mar 16, 2009 | 05:17 PM
redbull-1's Avatar
3 belts? The drive belt is one belt, you move the auto-tensioner so the belt can be removed and new one installed. Here is a routing diagram:
Old Mar 21, 2009 | 04:33 PM
hey thanks man im all set u can take out the picture. I replaced the caliper, left side cable was not working.. and ebrake work as new. also replaced the belt.. man it was a b**ch but i got it.. thanks man
Old Mar 21, 2009 | 05:44 PM
redbull-1's Avatar
Done. Glad it worked out for you.
techsupport
Mar 29, 2017 08:43 PM
Jason777
Jul 7, 2014 02:06 PM
patrickvertigo
Aug 7, 2010 07:23 AM
dankafcas
Jun 8, 2008 04:27 AM
SPL KID
Apr 16, 2004 07:34 PM
