Temperature gauge reading cold...
Old Mar 11, 2009 | 11:33 PM
the soL that could's Avatar
Default Temperature gauge reading cold...
Temperature gauge reads between Cold and Hot when not in motion. As soon as i drive, it drops towards "C" cold. When I turn on my heater… it’s somewhat warm and the temperature gauge reads all the way to "C". What can be my issues? thanks in advance.
Old Mar 12, 2009 | 12:05 AM
lazyxmofo's Avatar
Default Re: Temperature gauge reading cold...
your temp gauge is probably dead. just get a new one
Old Mar 12, 2009 | 07:03 AM
mouab18c1's Avatar
i would check your coolant level...seems to be air bubbles in it
Old Mar 12, 2009 | 08:20 AM
bawlinteg's Avatar
my car runs cool also..runs fine though
Old Mar 12, 2009 | 10:18 AM
Gsr94black's Avatar
thermastat is probably stuck open...mine did that a few years back
Old Mar 12, 2009 | 06:06 PM
jdmjoka's Avatar
DB squad #282
mine does same thing i run cold all of the time!
jdmjoka's Avatar
DB squad #282
And i've changed the temp gauge. Autop zone told me try the tempature sending unit. like 8 bucks
Old Mar 12, 2009 | 06:54 PM
neof69's Avatar
Replace thermostat.
Old Mar 12, 2009 | 06:57 PM
olskoolcivic's Avatar
stuck open t-stat or no t-stat,good luck !!!
Old Mar 12, 2009 | 07:31 PM
vladd's Avatar
it's the thermostat. it's a really common problem on integras. get a new one from the dealer.
Old Mar 12, 2009 | 07:44 PM
Gant's Avatar
dont trust autozone for diganosis, i HAD THE SAME problem its a thermostat, its stuck open, when i removed mine YOU CAN easily push it in so the coolant was easily opening the thermostat
and to the guy that said theres air bubbles if that was the case the car would overheat due to air in the system
DO NOT run your car with a stuck open thermostat, while some ppl think its good because the motor is cold, the car would stay in closed loop and run rich all the time, you would waste gas, and sooner or later running rich your going to destroy your cat.
Old Mar 14, 2009 | 04:15 PM
luisrblue's Avatar
where in the world is the thermostat on 95 integra ls, its a b18b1 (or 1b not sure) auto zone couldnt find it, neither could a mechanic, help! [noob]
Old Mar 14, 2009 | 06:11 PM
AMLS4dr200whp's Avatar
had this same problem it was the thermostat and replaced it went to normal. its thermostat as said above
Old Mar 14, 2009 | 06:20 PM
Si-Yaaa!'s Avatar
I had the same problem too and just swapped out my thermostat last weekend as well and it fixed the problem. Now it's a happy integra again. I ordered mine from hondapartsunlimited.com.
Kalen13
Honda CR-V & Element
Jan 18, 2018 11:04 AM
boarding2008
Feb 1, 2009 04:00 PM
Zee.I
Jan 22, 2009 05:10 PM
-BlueGSR-
Dec 16, 2002 10:35 PM
Sir_Phobos
Dec 7, 2002 08:45 AM
