15 inch vs 16 inch wheels on a del sol
Old Mar 11, 2009 | 07:48 PM
ilovejdm's Avatar
Default 15 inch vs 16 inch wheels on a del sol
Which do you think is a better look? I've been debating on what size I should order my new wheels. Little help??
Old Mar 11, 2009 | 08:56 PM
drewskie's Avatar
Default Re: 15 inch vs 16 inch wheels on a del sol
15 ftw
Old Mar 11, 2009 | 09:03 PM
EK9r!der's Avatar
^^^ x2... also what kind of wheels you looking to get?
Old Mar 11, 2009 | 09:13 PM
B2KHonda's Avatar
im rocking 15" heliums with 205/50/15 and a 2 inch drop. looks real good, so go with 15's
Old Mar 11, 2009 | 09:29 PM
ilovejdm's Avatar
my del sol is silver with black ex front lip and stock black sideskirts, black housing headlights with amber corners lowered on sportlines
Wheel Choices:
black rota slipstream with polished lip
polished slipstreams/nippon f-2
white circuit 10's
white spun sk...whatever they are...
any suggestions??
Old Mar 11, 2009 | 09:45 PM
raidacaipo's Avatar
hrmmm.. I personally like 15" 205/50/15..
Old Mar 11, 2009 | 09:48 PM
bmoua's Avatar
Best combo wheel/tire for all 88-00 Civic/Integra/Del Sol/Crx. I wouldn't mind 16inch rims (has to be the right rim) but 15inch rims just plain peform better.
Old Mar 11, 2009 | 09:50 PM
EK9r!der's Avatar
i think the black slips would look clean.
Old Mar 11, 2009 | 09:52 PM
ilovejdm's Avatar
I think so too, it's really between the black slips with polished lip or entirely polished slips
my buddy is trying to sell my some green j spls, lol but I'm not really into bright colors....
Old Mar 11, 2009 | 09:54 PM
EK9r!der's Avatar
i would go with the polished slips if you can!!! especially on silver!, but then again the black slips would match your lip, side skirts and headlights... so idk man its 50/50.
Old Mar 11, 2009 | 10:05 PM
ilovejdm's Avatar
sigh...I hate buying wheels, with hondas you have so many options
I miss buying wheels for mustangs, basically you could buy cobra wheels or bullitt wheels haha
Old Mar 11, 2009 | 10:09 PM
EK9r!der's Avatar
true but that's what makes hondas so especial, you got many options unlike domestics, if you really think about it they all look the same sort of, when i had my ss as far as wheels the only thing i liked where the c6 vette rims.
Old Mar 11, 2009 | 10:21 PM
trustdestruction's Avatar
15"x6.5" with 195/50/15 tires is what I would use.
My sol on those size Drag DR-23 wheels with falken ziex 512 tires
(sorry for so many pics, figure more angles gives you a better idea of what that size wheels/tires look like)
(and don't worry, I got rid of the ugly chrome valve caps... lol)
Old Mar 11, 2009 | 10:29 PM
ilovejdm's Avatar
car looks good, what made you decide to go with 195/50's? This isn't my first del sol btw, I had a black one with polished slips as well 205/50, I've just been debating on if I wanted to get a bigger wheel for my new car when it gets out of the body shop.
heres a pic of my last del sol:
haha very true, I think that's what always brings me back to hondas. With Hondas and imports in general you can do things to your own style and be accepted by the community. I think the problem with domestics is too many old men and ignorant rednecks bash on you if you do anything different.
Old Mar 11, 2009 | 10:39 PM
Thanks.
I went with the 195/50 because that's the size that gives you the same overall diameter as stock. Plus, you don't need 205mm treadwidth unless you're autocrossing or something like that. It's overkill for even a spirited DD'er. (at least on a del Sol).
205/50 and 195/55 are what gives you near stock diameter on an EK civic.
Old Mar 11, 2009 | 10:46 PM
ilovejdm's Avatar
Originally Posted by trustdestruction
Thanks.
I was unaware of that. I have just always ran 205/50's on all my civics/sols
Old Mar 11, 2009 | 10:53 PM
Yea, i'd also like to further clarify...
You can of course run that tire size no problem.
Basically, 195/50/15 is closest to stock overall diameter for del Sols and EGs, and 195/55/15 or 205/50/15 is closest to stock overall diameter for EKs.
Old Mar 12, 2009 | 12:02 AM
Jedi_Sol's Avatar
15" look proportionally look better. Plus they are lighter and you get better handling performance compared to 16's. Tires would be much cheaper too.
Old Mar 12, 2009 | 01:09 AM
SuckMyDOHC's Avatar
Thanks.
nothing wrong with a 205mm width for a DD. The 10mm gives you better grip but does also make the steering a bit stiffer. I'm running a 205 width on all three of my cars and plan on running a 215/45/16 on my R for normal usage.
anyways, my point is that if you can get more planted on the ground without any issues, why not?
Old Mar 12, 2009 | 06:43 AM
I'm talking about a 15"x6.5" rim though. 205mm treadwidth is standard on a 16"x7" rim on a Civic.
And i'm not saying there's anything wrong with it, i'm saying that it's just not necessary.
Plus, on a lowered del Sol with 205mm treadwidth and a sidewall height that makes the overall diameter of the wheel & tire closest to stock, it will rub in some way, shape, or form, regardless of the offset. I've been there and I know it will.
I had 17"x7" rims (yes, I know... don't worry, I hated them too) with 205/40/17's and a +40mm offset, and they rubbed the inside of the wheelwell around tight turns and the lip of the fender. I am lowered 1.8" front, 1.6" rear.
That being said, no matter what offset I was using, I would have rubbed with the 205mm treadwidth and closest-to-stock-diameter tires, because either direction changing the offset would have moved the rim may have eliminated rubbing on one side, but it would have made it worse on the other.
On a moderately lowered del Sol, 205mm treadwidth tires that are as close to stock as possible in overall diameter will rub in at least one way, regardless of the wheel's offset.
Old Mar 12, 2009 | 07:47 AM
MonkeyMagic's Avatar
fuuuu
16
josliver
19
Mar 2, 2018 10:10 AM
From_love
Sep 17, 2006 10:21 AM
Drift-King
44
Aug 12, 2004 04:25 PM
SOHC Si
Sep 11, 2001 05:47 PM
