shifter noise
Old Mar 11, 2009 | 06:26 PM
Midori Green's Avatar
Default shifter noise
My car is making this wierd growling noise and i noticed its coming from my shifter, now it only happens mostly in 1st or 2nd gear once i hit abour 2500 rpm's or higher that growling sound kicks in but i just have no idea would could be causing it. By the way my tranny does not grind or pop out and all gears work fine. The shifter is a skunk2 dual bend.
Old Mar 12, 2009 | 05:17 AM
Default Re: shifter noise
any thoughts?
Old Mar 13, 2009 | 06:47 AM
Old Mar 13, 2009 | 08:33 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Sounds like the shifter is hitting on the exhaust in far left gears. Is it a swapped car? Mine rattled against the exhaust for awhile after my swap until I got the exhaust lengthened about 1.5" in front of the cat.
Put it in first, then get under the car and wiggle the exhaust around. How close is it to the bottom of the shifter? Is it hitting at all?
HellaFab
Oct 28, 2011 07:40 AM
RSX_S
Jul 8, 2008 08:10 PM
Delano5050
11
Aug 20, 2007 12:40 PM
SiKSi2K
Nov 8, 2004 08:31 PM
jdm2k_si
16
May 15, 2004 04:52 PM
