leaking valve guides harmful?
Old Mar 11, 2009 | 04:23 PM
Swapped94's Avatar
Icon2 leaking valve guides harmful?
i have a b16a2 and just found out two of my valve guides are leaking. other than burning oil will this hurt my motor at all or loose power? does anyone know or havee the same problem
Old Mar 11, 2009 | 05:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: leaking valve guides harmful?
well anytime you are trying to burn anything other than gasoline, yeah it may be down a little on power, may not even be noticable.
just keep on top of the oil level and you shouldnt have any issues.
Old Mar 11, 2009 | 05:47 PM
instructor74's Avatar
okay so your burning a bit of oil because of leaky lavel seals. Its no big deal I have owned cars that when I pulled in to a service station I had them check the gas and fill up the oil. I have never had an engine die because of it like posted already just keep an eye on the oil and you will be fine
Old Mar 12, 2009 | 01:01 PM
Swapped94's Avatar
will they get much worse over time
Old Mar 13, 2009 | 03:24 PM
Mr. Badwrench
your guides are probably wearing out also. if thats the case yes it will get worse in time.
Old Mar 13, 2009 | 03:53 PM
lcsej1's Avatar
i wonder what happens to the cat with all the oil going through!
timbo74
Apr 10, 2019 05:59 PM
toyonda
Jan 28, 2009 05:45 PM
diilbert
Honda Civic (2001 - 2005)
Oct 3, 2007 02:03 AM
opiumdaze
Apr 23, 2005 02:20 PM
