Making tubing anchors?
Hey guys,
Just wondering what is the proper way to fabricate the anchors used to attach a tube. Not sure what they are called, but you see them all the time.
I have been welding a washer to the end of a tube, but I'm not too thrilled about welding zinc-coated unknown-grade washers into my structures. For larger diameter, I was thinking of just making circles out of steel plate.
What do you guys do?
Thanks!
(the little buckets).
Thanks!
If it is a one off, I've used grade 8 or metric 10.9 washers and bead blasted off the zinc before welding. The lathe method would be ideal since you could make it nice and thick but VERY time consuming.
Best method is laser in my opinion but that just isn't practical for the normal fab projects.
Here are a few we did a while back:
I could bang one out on a lathe faster than you could cut and weld one, a lathe is much faster, if you have a good lathe with good tooling and the proper knowledge on how to use it.
that sounds like a hefty hydro bill markku.
i make mine out of solid round stock. i have a couple lying around if you need them quick. if i don't have the size you want, i can proabably make some up.
aaron
aaron
When I did work for Lonestar Racing, the "anchors" they used were made from round bar, and were about 3/8" thick. Half of it (3/16") went inside of the tube, the part that went outside matched the od of the tube, and had a pre-machined bevel for welding. And there was obviously an appropriately sized hole in the middle.
They were freaking rad.
Pics for clicks, not the anchors, but shop pics. This place was pretty cool.
http://www.lsracingsidexside.com/vie...gallery_id=8#5
Note sure if this is what you are looking for / talking about
http://www.ballisticfabrication.com/...pters_c_7.html
or
http://www.hrpworld.com/index.cfm?tp...ction=category
Most are threaded for rod ends but maybe they would work for you application....
Dave
#72 ITS GSR
AMB transponder repairs.... ask me how
or
or
[QUOTE=dave@passenger;37740322]I could bang one out on a lathe faster than you could cut and weld one, a lathe is much faster, if you have a good lathe with good tooling and the proper knowledge on how to use it.[/QUOTE
Not for one off stuff. Maybe if you had every size OD bar stock laying around. Tell you what. You start off with a piece of 2.00 or bar stock and I'll start out with a piece of .125" cold rolled sheet. We can both make a 1.5" washer and lets see who is faster
Now I totally agree if it is a job where you will need to make a quantity. But then again, at that point why not have them laser cut for under a buck each.
How much would it cost to say......have 70 made with an o.d of 1.25"
and a hole size of 10mm on a lathe and roughly 1.5" tall? Also have the base/landing be say .1 thick and the walls be around the same
we have a similar part that we use on the upper a arm.the price is around 10 dollars for an order of 20.it would be even cheaper if you went to 70.the cnc laths can jam these parts out in no time.
What machine shop does work like that for 50 cents per piece in small quantities. You must be providing the material at least.
[QUOTE=Sims;37766833]
IF all you want is a washer, just buy a washer. A lathe is way faster for making these little buckets, even for one offs.
