d16Y8 head and d16z6 block...__what head gasket and belt ??___
I did search but found nothing ...
I'm bolting my Y8 head to my z6 block not sure what head gasket or timebelt to use...
I was told that the d16Y8 gasket is thinner is this true?
Thanx...
Thanx...
The y8 I believe is a 2layer OEM gasket. Between the Z6 and Y8 heads I dont think it matters which one they should be interchangable (dont quote me on any of this). But with the Y8 gasket it should bump your CR up a little bit. The timing belt I believe you would use the one with the head, in your case the Y8. Though it might not matter cause they too COULD be interchangable. Bump for this man
Mattmob
Nov 8, 2006 04:53 PM
sinfulj32
Nov 29, 2005 06:54 AM
