cleaning the IAVC
Old Mar 11, 2009 | 11:50 AM
Rtboy10's Avatar
Default cleaning the IAVC
I see that there is an allen key is it ok to open that to clean inside of it or should I just leave it be. Also I was wondering what kind of oil should I be running I have a b18c1 built with 11.5.1 compression and a built head and what not I am currently using castrol gtx 10w 30w and an oem filter any opinions on what I should be using.
Old Mar 11, 2009 | 11:53 AM
chicows18's Avatar
Default Re: cleaning the IAVC
If you problem is idling up and down, the only thing you can do is clean the two ports on the valve. I usually just spray some carb cleaner and then blow it out with air. Usually its the one with the screen that you have to clean thoroughly. As for the oil, 10-30 is fine.
Old Mar 11, 2009 | 11:59 AM
Rtboy10's Avatar
thanks for the reply
Old Mar 13, 2009 | 12:39 AM
jdmposer's Avatar
be careful when cleaning the screen, dont damage it or else it wont work properly
jaepalm
Honda Civic (2006 - 2015)
10
Aug 8, 2008 09:23 AM
Root of all Evil
22
Mar 13, 2008 02:09 PM
ramz7887
Sep 13, 2003 07:47 AM
Havokmkr
Apr 6, 2003 11:02 AM
