cleaning the IAVC
cleaning the IAVC
I see that there is an allen key is it ok to open that to clean inside of it or should I just leave it be. Also I was wondering what kind of oil should I be running I have a b18c1 built with 11.5.1 compression and a built head and what not I am currently using castrol gtx 10w 30w and an oem filter any opinions on what I should be using.
Re: cleaning the IAVC
If you problem is idling up and down, the only thing you can do is clean the two ports on the valve. I usually just spray some carb cleaner and then blow it out with air. Usually its the one with the screen that you have to clean thoroughly. As for the oil, 10-30 is fine.
Root of all Evil
22
03-13-2008 02:09 PM
ramz7887
09-13-2003 07:47 AM
