What kind of oil should I use?
I have a built b18c1 with 11.5.1 compression built head and what not I have always ran castrol gtx 10w 30w with a honda oil filter. I was wondering if I should use anything else?
i like amsoil HDD 5-30. i would prefer 0-20, but i'll take the higher zinc and phosphorous content over better cold flow.
https://www.amsoil.com/storefront/hdd.aspx
Go to www.bobistheoilguy.com and do some research.
5w-30. lighter oil increase gas mileage. idk about the b18c's but I know the obd1 b16a's says it should use 10w-30 while the obd2b uses 5w-30. i have a obd1 b16 and i noticed a difference from 10w-30 to 5w-30 in gas mileage for sure. i'm a mobile1 or castrol guy myself.
I use Torco now ... But I have always used Valvoline 10w30 in the past for years. Redline is also good. I think that Torco is better though.
But if it runs good with what you have been running then just keep running it.
CC thank you that link was very informative thank you everyone for the response. CC I need to talk to you about getting some head work done, any deals if I send in two heads?
Torco Oils: some dyno data here: http://www.bisimoto.net/forum/viewforum.php?f=30
i ran royal purple 10w40 in my boosted b16. gonna run the same in the boosted gsr.
i think royal purple is a pretty good deal at 6.99/qt.
oil temps come in huge when it comes to making power. dont think a certain oil will make a certain gain because you see it; unless you key in the right factors in a controlled environment.
Originally Posted by namewasdallas
id use torco after seeing the gains that it made,
v0lcom27
22
Jul 13, 2005 07:30 AM
