usdm itr 22mm sway bar wont fit??????
ok i just got off the phone with jhp and they told me if i do the asr rear brace and the skunk2 lca's that a usdm itr rear 22mm sway bar will not bolt up to the sk2 lca's for a reg integra? i thought it would be no prob. lmk know if it will or wont. i know the itr control arms are diff but the end link wont work?
It should work fine with stock end links if the LCA end link holes are in the correct location. I think Skunk2's newer LCA's do have the correct sway bar hole location, so I don't see why it wouldn't work.
Aftermarket adjustable end links are almost all junk. I would try everything possible to try to get stock end links to work.
Is is possible the GSR and ITR endlinks are different?
52303-ST7-Z00 ITR Part number
52303-SH3-020 GSR Part number
I believe you need the ITR part to make it work correctly.
i dont think you need the endlinks every writeup i found was showing that you reuse the old endlinks and just use the itr bushings here look lmk what u think
http://www.team-integra.net/sections...?ArticleID=692
but now i keep reading people have a pain in the *** time getting the stock ls/gs/gsr endlinks in the lca's??? anyone have any info on this? will it be easier to just get itr endlinks?
snowboardgeek1
Aug 15, 2014 06:46 PM
. o 69 o .
Suspension & Brakes
40
Aug 23, 2005 09:49 PM
