5th gear pops out
Well as the title describes. 5th gear pops out after checking the shift cable for corrosion, replaced 5th gear synchro, check MTF OK. Has anyone has this same problem with 5th gear????
My mechanic checked everything out everything inside the tranny as far as the gears syncro.
1-4 works perfectly
Reverse works perfectly
5th gear is the one that pops out.
no grinding of gears, not even when i put the car in reverse.
alot of these threads talk about shift forks???? any ideas.
1-4 works perfectly
i used to drag at morosso in FL.
99 integra GSR
turbonetiks 15 pounds of boost
HR racing springs
Greddy exhaust header back
Racing Hard 17" wheels
nothing fancy, just for fun. I was never really technical on doing it myself. But now for some reason i find it interesting as a personal hobby to build an 03 civic hatch from the ground up.
99 integra GSR
HR racing springs
99 integra GSR
HR racing springs
99 integra GSR
HR racing springs
99 integra GSR
HR racing springs
99 integra GSR
HR racing springs
Dude the only thing I would guess is your MTF but you said you already checked that. If I was you I would top it off just to be safe. I know mine started doing this all I had to do was fill it up and it hasn't done it since.
its topped off and still no luck. i have gone through different forums and find that it could be a shift fork problem. im guessing. does anyone have additional information that would help me out with this??
times right now are hard, so im trying to find the best way out.
does it sometimes pop out of 3rd also? I had a problem with the shifter popping out of 3rd and 5th, turned out to be a sticky pivot ball at the base of the shift lever. Try giving that a squirt with some WD or lithium grease.
I know honda makes a updated case half for that trans and I would say shift forks and also the 4-5 sleeve and hub. Go to your local honda dealer and ask them about any service bullittens on your problem.
its either the slider is ****ed up, the synchro spring, the synchro(you cant tell its the synchro just by looking at it unless its really bad) or the bearing. rarely is it ever a shift fork.
thank you all for your support on this.
Here is my check list
Checked
countershaft, gears, synchro assembly Ok
Main Shaft, gears, synchro assembly OK
Fluid OK
New clutch assembly
shift linkage, cable, OK
Transmission housing OK
I suspect shift forks? The only thing i can think of
Checked
Fluid OK
New clutch assembly
Checked
Fluid OK
New clutch assembly
Checked
Fluid OK
New clutch assembly
X2. My 5th gear popped out a few times shortly after a swap. I just forgot to top off the tranny fluid. Filled her up with honda MTF and all is well.
BULL3TPR00F
Feb 14, 2012 10:00 PM
