Timing Belt Swap ?'s
Old Mar 10, 2009 | 09:45 AM
fallen87's Avatar
Default Timing Belt Swap ?'s
the timing belt feels like its stretched and very loose,
and I need to replace it asap. this is my first time pulling the head off a car it looks really simple..is there anything else i need before swapping?
1.Tools
2.Chiltons Manual
3.Timing Belt
4.Water Pump
Old Mar 10, 2009 | 10:22 AM
DRAMA's Avatar
Default Re: Timing Belt Swap ?'s
might as well change out the tensioner since you'll have it out. It's a cheap part.
Old Mar 10, 2009 | 04:11 PM
fallen87's Avatar
k thx man, i was told i'd need to replace the water pump because
usually you mess them up putting the belt back on..
I want to clean the head while it's off what should I use to clean it?
Old Mar 10, 2009 | 04:16 PM
arrocha87's Avatar
u mean the top part that covers ur head? thats the valve cover and if you just want to clean it you can degrease it for a while and rinse and repaet, maybe use a scrubbing brush.
if ur going to paint it you can sand it all the way down and use high heat paint to re-spray it. you can either tape off the letters or just sand them down once u paint it.
lilskud13
14
Mar 26, 2009 01:28 PM
brunorahl
Jun 4, 2006 06:52 PM
mycivic93dx
Jul 3, 2005 06:57 AM
1hotintegra
Jun 16, 2003 03:10 PM
miketegra
Feb 24, 2003 08:59 PM
