My Future setup (please comment) good or bad
Ok so I have a 95 GSR 145,xxx
I already have the following parts...(Not installed yet)
*Blox HSL cams
*AEM cam gears
*Omni Power Valve Springs
*Omni Power Titanium Retainer Set
*Omni Power Intake And Exhaust Valves
*Hondata S200 OBD1 Honda ECU
Thinking of upgrading Pistons/rings and rods w/...
*B16 CTR Pistons
*Spoon SPort Balanced JDM Type-R Pistons
*JDM B16 SIR2 Standard w/rings
Which rods should I go with? Is it necesary to upgrade rods? Can I use stock? Please help...
Also, I was thinking of getting a stripped type R head and dropping in the parts to that one... What do you guys think???
*Blox HSL cams
*AEM cam gears
*B16 CTR Pistons
um ,,, ok pulled all the stuff into the gsr head, get a hybrid intake manifold, and i wouldnt buy spoon con rods, there a waste, get eagle rods. and then i would use the B16 pisons and new rings, it all depends what your goals are
allspooledup
Mar 15, 2007 08:48 AM
