vtec solenoid bad or sensor!?
i have a swapped h22 and it has a rough idle on occasion and is not hitting vtec...still goes thru entire rpm range? anyone have any ideas as to it being the solenoid or sensor? please HELP!!???
sounds like your oil level might be too low. CEL meaning a check engine light on your instrument cluster.
What ecu are you using? you might not have the right ecu, and thats NOT good for your h22.
COMplex.
Jul 17, 2003 05:51 PM
