Installing Aftermarket Tachometer
Hey guys,
I just bought a tach for my '90 Honda Civic (HB), and I've run into a bit of an installation problem. The tach instructions tell me to hook a wire to the coil... but my car doesn't have one. (The motor is a D15b1, if that helps.)
So how do I hook this bad boy up?
Buy a 90-91 Civic Si/CRX SI Cluster and sell your aftermarket tachometer, SI clusters of the same year are plug and play.
Also, it means the distributor. there is a wire you have to splice to use an aftermarket cluster.
Anyway, I think I figured it out.
kk, Go ahead and spend the extra time, i'm just trying to save you time and money.
Cluster comes off with 6 easy screws.
2 for the hood, and 4 holding the cluster...
It's one of the wires that on the 2-wire plug, don't remember what color it was i just ripped out the tach the previous owner put in and installed an SI Cluster.
And thanks for helping me out. I'll go check it out.
Yup, blue wire off the two wire harness on the distributor.
You might also be able to use the same colored wire coming from behind the cluster so that you won't have to run a wire to your engine bay.
Yeah. I think it comes out of the harness on the firewall by the driver's side. I think I could just splice into it right there.
Euphorex
Oct 31, 2013 02:53 AM
Civic89stdB16
Sep 7, 2007 02:45 PM
04, 2003, acura, aftermarket, civic, cluster, coil, distributor, ef, honda, ignition, installing, tach, tachometer, tl
