Motor Mounts .. what do you think?
Old Mar 9, 2009 | 12:26 PM
del_sol 2009's Avatar
Default Motor Mounts .. what do you think?
Would 2 missing front motor mounts, cause a car to shake only when turning?
My car 94' Del Sol si
B16A motor
THANK YOU
Old Mar 9, 2009 | 12:29 PM
DRAMA's Avatar
Default Re: Motor Mounts .. what do you think?
With stock motor mounts used on the sides and rear, yes it'll vibrate more but it's still driveable. With stock motor mounts, the rubber inserts will tear faster w/out the front mounts.
If you don't want to run the front mounts, at least get the ES urethane inserts that you can put into the stock remaining mounts. The car will vibrate more but the engine will not move.
Old Mar 9, 2009 | 12:48 PM
Its kidna strange.. im trying to diagnose why my car shakes only when i accelerate through a turn.. my first thought were the cv joints.. but just had them checked and they boots and axeles appear fine. So i thought it may be the engine knocking around when i turn.. because of the missing motor mounts.
Old Mar 9, 2009 | 02:17 PM
unusual71's Avatar
the front mounts your referring to are called torque mounts and are mainly there to stabilize the motor from front to back. without them the motor could be torquing back enough under acceleration that it causes a vibration but i think there is probably some other problem
Old Mar 9, 2009 | 02:31 PM
oh ok.. I will probably cave and take it to the local Honda Dealer and let them have a look.
thanks for the help.
1LowSol
16
Jun 13, 2009 12:54 AM
hondaapi
Oct 20, 2008 01:52 AM
GuCBlackEk
Oct 2, 2008 06:06 AM
Ross
Jul 18, 2004 10:21 AM
RTW DC2R
May 4, 2004 03:22 PM
