Which head will make the most power from a d16z6?
Old Mar 9, 2009 | 08:55 AM
98formulaLS1's Avatar
New User
Default Which head will make the most power from a d16z6?
Is there a better OEM head that will make more power on my z6? I don't want to replace the block if I dont need to, but I did hear that an a6 block and a z6 head will make more power.
Old Mar 9, 2009 | 08:59 AM
thumper64's Avatar
Default Re: Which head will make the most power from a d16z6?
That is because the A6 has a slightly shorter deck height. You could mill the Z6 head or block and get the same effect.
The Y8 head has a bit higher compression, and quench pads to help prevent detonation, but the Z6 is said to flow a bit better.
Old Mar 9, 2009 | 09:03 AM
94civicdeleon's Avatar
Stick with the Z6 if you can if it's not Vtec then just get a Vtec head. You don't wanna change heads and all that stuff for maybe a extra 1-2 hp gain and maybe 1-2 ft tq. The Z6 is the best to stay with unless you just get a completely different motor swap. What kind of car is this going into.
Old Mar 9, 2009 | 09:32 AM
leroyb's Avatar
d15b head will give u the most power because it has the most agresive cam out of all the dseries
Old Mar 9, 2009 | 09:35 AM
weavertime1's Avatar
All d16Z6s are VTEC...
Old Mar 9, 2009 | 10:04 AM
Ohh hahaha my fault wasn't thinking....
Beasty91Hatchy
Oct 28, 2010 01:51 AM
toolbox21
Jul 22, 2008 06:24 PM
yz125rider21
Dec 10, 2005 09:31 AM
poetter
Oct 23, 2004 11:43 AM
98jdm_coupe
Apr 15, 2004 09:28 PM
