JDM b20 in EK hatch help!!
Well, i just picked up a jdm b20b motor and noticed that it doesn't have a knock sensor nor does it have a cranks sensor. What should i do about this. I've got a 96 ek hatch. Will my car run sh*tty without those two sensors? what can i do to get these sensors. can i just buy a knock sensor and install it into the back of the block where its suppose to go cause i believe i saw a threaded whole for it. as for the cranks sensor what should i do? please help me cause the car is my daily!
I say you need them and my supporting evidence; however, it would be beneficial to pick up a Haynes for a CRV and you car. I would also reccomend building the motor up a little before you drop it in, B20 VTECs are hella sweet. Someone else might have to anser the mounting portion because I have never had an issue and mine are fine.
http://www.google.com/search?hl=en&r...3Acrank+sensor
http://www.google.com/search?hl=en&r...3Aknock+sensor
But then again from what I remember it will run if they are hooked up to the harness and not where they are suppose to be and you might as well do it 100% legit, so you don't have to go back and do it again.
i believe only vtec engines come with knock sensors. but OBD-2 engines come with crank sensors.
just do this, get an OBD-1 LS ecu, and get the jumper harness for OBD-2a to OBD-1 and there you have it, no crank sensor and no knock sensor. (and alot less CEL's now that you'd be OBD-1)
http://technet.ff-squad.com/ckftrick.htm
go there and it will tell you how to take care of your crank sensor problem if you decide to stay obd2
Here is a good thread about B20s:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-non-vtec-faq-guide-including-p8r-head-information-1467903/
According to the above link, "All 99-00 B20's have a knock sensor, regardless of where it comes from, which signifies the high compression 9.6:1 motor. If your B20 does NOT have a knock sensor, it is not the 9.6:1 compression motor"
thanks for all the info. and as for the motor i have a 97 jdm one. anyone no what to do about the knock sensor if i decide to keep it obd-2?
there is no reason to keep it obd2 because a b20 wont smog anyways, so there are no gains to keeping it, you should get a knock sensor, unless your running an ecu made for a car without, and if your gonna run obd2 youll need the crank postition sensor.
Depends on your state laws. In RI, there is no restriction on the motor, but they plug right onto the OBD2 port for emissions.
SLO-hatch, if you "plug in" for inspection in CT, you're going to have to make it work. KS can be added fairly easily and Katman's CFK trick that waynecoSI linked is even easier.
Did you know you bought the 8.8:1 motor instead of the 9.6:1? You sound surprised that it didn't have a knock sensor.
thanks for all the info guys!
no i got it through a trade for my messed up gsr motor. and also got 100 bucks out of it. and got to keep my arp head studs... you guys think its a good deal? and it was the one that came with the giraffe intake mani. and the p8r head.
if it was me and all i was running was that B20 i would just leave it obb2. get a obd2 LS ecu get a obd2 oil pump and obd2 distributor. oh and get the crank sensor and ECU. After that wiring is a breeze. Thats if you want to pass inspection. smog dont matter in CT like it does in cali. Here in texas as long as there are no codes on a OBD2 car it will pass emissions. So idealy it would have been better to get a OBD2 swap. or you could just go OBD1 and not buy as many parts. but if it is anything like here in texas you will be out of luck on inspection.
