Stock ITR cams with cam gears timing help!
Hi Everyone,
I want to ask a question about timing with adjustable cam gear.
I have a jdm b18c 98+spec engine, stock compression 11.3 and stock ITR cams,4-1header 2.75" full exhaust cold air intake,crower cam gears, aem fuel rail and regulator, aem ems 1020. I want to revving 9000-9200rpm.
what is the best timing to my engine? I think, +2deg advance intake and -1deg retard exhaust are fine.
what do you prefer?
Thanks a lot.
what do you prefer?
Thanks a lot.
every setup will be a little different, the only way you will find your best timing settings will be to put it on a dyno and advance or retard your timing from there.
