B16B engine part numbers please
Old Mar 8, 2009 | 08:49 PM
centralman's Avatar
Default B16B engine part numbers please
Hi everyone I am a newbie here I am buying a 99 Civic which has a JDM B16B installed. If you guys be so kind to provide me with part numbers for timing belt and water pump, would like those replaced ASAP, thanks.
Old Mar 8, 2009 | 09:04 PM
joelmatt89's Avatar
Default Re: B16B engine part numbers please
go to majectic honda or any other website that sells them just fill in your info and when you select the part it will show you the parts number
Old Mar 8, 2009 | 09:08 PM
1797cc's Avatar
The timing belt is part # 14400-P72-014, and i don't have the water pump number of the top of my head but its the same as a b18c gsr water pump. hope this helps
Old Mar 8, 2009 | 09:17 PM
centralman's Avatar
Thanks guys.
So it uses the same timing belt as the B18C1 & B18C5 does?
Base on this then the Water Pump should be # 19200-P72-013.
So everything with the engine just use this as a rule of thumb? From valve cover gasket all the way down to the oil pan?
Old Mar 8, 2009 | 11:11 PM
1797cc's Avatar
you are correct
Old Mar 8, 2009 | 11:16 PM
centralman's Avatar
you are correct
My thanks to you again.
Old Mar 11, 2009 | 09:37 PM
centralman's Avatar
I am sorry I posted the wrong info. I double check the engine block and the seller's description it's Honda Integra (JDM) B18B engine. So now do I just use the 1999 Integra GS or LS parts listing to get the engine parts?
Many thanks
Old Mar 11, 2009 | 09:56 PM
Deetz's Avatar
Crazy Honda Guy
^^ yes, a jdm B18B is the same as ours, so any RS/LS/GS parts fit the same
Old Mar 11, 2009 | 10:21 PM
centralman's Avatar
Thanks for the info.
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
HONDAEG6gsr
Sep 13, 2012 10:51 AM
the soL that could
Jan 12, 2011 09:40 PM
vvboy
Jul 5, 2010 11:21 PM
SlammedDC2
Jun 11, 2007 07:53 PM
