B16B engine part numbers please
Hi everyone I am a newbie here I am buying a 99 Civic which has a JDM B16B installed. If you guys be so kind to provide me with part numbers for timing belt and water pump, would like those replaced ASAP, thanks.
Re: B16B engine part numbers please
go to majectic honda or any other website that sells them just fill in your info and when you select the part it will show you the parts number
The timing belt is part # 14400-P72-014, and i don't have the water pump number of the top of my head but its the same as a b18c gsr water pump. hope this helps
Thanks guys.
So it uses the same timing belt as the B18C1 & B18C5 does?
Base on this then the Water Pump should be # 19200-P72-013.
So everything with the engine just use this as a rule of thumb? From valve cover gasket all the way down to the oil pan?
I am sorry I posted the wrong info. I double check the engine block and the seller's description it's Honda Integra (JDM) B18B engine. So now do I just use the 1999 Integra GS or LS parts listing to get the engine parts?
Many thanks
Many thanks
Falloutkid90
Honda Civic (2001 - 2005)
03-19-2024 07:30 AM
vvboy
07-05-2010 11:21 PM
SlammedDC2
06-11-2007 07:53 PM
